Mudstud
Who makes them and are they any good? My driver side has begun to collapse. Easy to see why, the freakin shim that Superlift uses isn't wide enough, putting undue stress on the perch where there is no support.
How do you guys feel about removing the Superlift shims? I think it's 4*s. I have factory front CV shaft with the anti bind things ground off. Front end has not been pushed forward- factory wheelbase. The first reason I ask is obvious, the second is cuz i have death wobble and a friend with a Toyota who had DW removed his shims and that solved it for him.
thanks, Dan
thanks, Dan
