who makes seals for rear sliding windows?
Cornfield creations
Jasper, Indiana
Does anyone know where I can get some seals and felts for the sliding back windows in the hardtop? I can't find them anywhere.
Not the seals between the window and the hardtop, the felt rubbers the windows slide in and the rubbers that fill the gap on the outside to keep the gunk out of the trough.
Hmm, don't see anything in previous posts. I saw a suggestion for trying an RV place. Of course check LMC and JC Whitney, but barring those, my other suggestion is least likely to be taken favorably, but infinitely the most practical. Toss the sliders and go solid. I know everyone likes the sliders, but when something goes wrong, they are hard to find parts for, as you are seeing.
If you can find gaskets/felt, no problem, but I think you are going to have a very hard time doing so. I know some canopies did use windows designed to look like K5 side windows, but the design isn't exactly the same and I doubt there are parts that will swap.
LMC carries the felt that the windowsd slide in. I know because I received a pair in error when I was trying to order the other piece that fills in the groove on the outside of the windows. I don't know where you can get those pieces.
try a good glass shop. thats where i got most of the stuff to rebuild mine. the right shop will be able to find a good replacement , but not the the exact original.:(
