I typed up a great big page full of info and opinions on each and my dam computer locked up and I lost it all
So I will just do a little recap..
I have read this whole thread and not one person has mentioned that any belt drive ATV is not good when it gets wet.. Once they get wet they will slip to the point of you not going any where.. Then when they do gain some traction they will actually spin themselves dry.. But the trouble is when this happens the centrifugal clutch will actually burn the belt dry so to speak.. After a few cycles of this the belt will sorta get a dry rottted affect and come apart from the stress and then your out almost $400 bucks for a new one.. I have seen this happen on more then one occasion on Polaris and Kawasaki..
Another thing I haven't seen mentioned is most if not all of these Polaris models are 2 stroke.. Like the Scrambler being mentioned for towing and utility.. A 2 stroke wheeler is the last thing you would want for utility because it lacks the power or for hunting due to the noise..Now a 2 stroke quad is fine for a play bike but it lacks the torque for any pulling power.. A buddy of mine has a 400 Scrambler that has a button to push on the right side handle bar to make it be 4wd.. It is a good for when your playing and get a little stuck then the 4wd button does provide some added traction.. But even in 4wd it dont have the torque to pull much weight.. To give you and example I still have my old Honda Big Red 250 3 wheeler and when we hook them back to back with a strap I can pull him backwards even though he is in 4wd.. The 2 strokes motors are not designed to pull weight because of the lack of torque they have.. His Scrambler has held up pretty good for a Polaris but there again it is belt driven that has slippage issues..
I like the Kawasaki Prarie all except the belt drive for the reasons I stated above.. But if it had shaft drive that would probably be my choice.. I have alot of hours on the 650 model and I'm impressed with the V-twin motor and the amount of power and torque that it makes. I like the lever on the the handle bar that enguages the front locking differential to make it a true 4wd.. It is has about a top speed of 60 MPH and plenty of power to pull a trailer or your truck around the yard.. It has enough off the line tourque to pull the front wheels off the ground and ride wheelies all day long.. It is great for utility use but still makes for a fun play bike..
Suzuki has always been a good choice over the years.. I don't have much seat time on some of the newer bikes but if they are anything the the older models I have owned they should be pretty good.. There are a couple fellows in my hunting club that have a couple of the new models and seam to be pleased with there performance.. One thing I do know for sure they are shaft drive which make it a better choice for pulling power and going in the mud.. I don't think they have the front locking differential though but I might be wrong.. If they do then that would be a plus..
Yamaha used to be the worst bike you could ever own years ago ''before Polaris came out
''.. They were known to break down and be made with out much quality control.. I have rode the Grizzley and a couple other models and from what I have seen Yamaha has come along way.. The couple people I know that have them seam to be happy with the ones they have.. Also the Yamaha is a shaft drive..
Now on to Honda you just can't beat their reliability.. I have been riding Hondas for almost 25 years and Have never been let down by their quality.. I stiill own 2 older Honda's and never have had any major issues.. The down fall to thier 4wd wheelers is the lack of true 4wd.. But they do make a front locker to fix that problem.. Honda has also seamed to be more expensive then the other brands on purchase price and parts.. But if they break down less I think it would even out.. They are also shaft driven so there again a plus..
Ok now Polaris once again I don't have much seat time with the newer models other then my buddies 400 Scrambler and a 500 Sportsman but they are 90's era.. I did have a older 250 Trail Blazer and it was the biggest piece of junk I have ever owned.. It was 2 stroke so it made to much noise for hunting and not reliable enough and lacked the power for any out of the way wheeling.. I think I spent more time fixing and working on that thing then I did riding it.. But in no way would I compare it to the newer models because I am sure they have made some improvement since then..I do know that the smaller Polaris kids quads are made by the same company that makes all the cheaper brands like E-TON and Polaris just puts their name on them..
I have been riding dirt bikes since I was 5 years old and not long after that I got my 1st 4 wheeler.. I have rode 2 and 4 strokes of both I even raced them when I was younger.. Even with my past experience it is still hard for me to make a decision when it comes time to purchase a newer model because there are so many to choose from with so many different features..
Like you said you can ask 5 different people what brand and model to get and you will more then likely get 5 different answers.. I can say that if the Kawasaki had a shaft drive and not belt it would be my choice.. Or if the Honda had a locking differential maybe I would want that one.. Or if Suzuki well you get my point
The best thing I can suggest to you is to go look at all the models and figure out which ones you would be interested in and the price of each... Then decide which features you like the most about each and carry a pen and paper with you to write them down so you don't forget.. The dealer should have brochures on each model too..Do alot of searching and reading on the net maybe even join a couple ATV forums so you can ask question there.. Then compare all your notes and the things you like and dislike and compare price.. When you think you got it down to which ones you want think about it for a couple more days then go look at your final decision.. Then post up the smiles on you and your kids faces for all of us too see
Good luck with your decision.. I hope that this might have helped ... I know with all the talking I just did I'm thirsty and need something to drink
