Who runs 44"s
yea front axle is moved forward via the 52" swap and another 1.5" with zero rates... 2" lift 52's and some home built shackles which may need a little more length (havent had it out flexed all the way yet), i had to do lots of measurements and thinking to get a good angle with the lift 52's , then the rear was superlift 12" i believe and i took out some leaves to get it to sit lower and flex somewhat better ... it isnt good enought for me though and it sits a little high in the back and has a 4" ord flip
JK5 said:
Mine has issues once in a while...I may be going full-hydro over the winter.
The hydro-assist will help.
Cool, you can install the full hydro after you get my 1/2 doors fabbed.......LOL :D
I got some steel...I just need the dies for my bender...
I'll build a bunch...the price will be good due to the price I got the steel. ;)
Basing110, got any more pics? Cardomain link?
Little driveway 'wheeling just to get flex shots. Hell, it's better then it just sitting on flat ground!! :D
k5 krawler 50 said:
x2, that thing is a monster..
I found this - CarDomain but I'd still like to see more pics if possible. Basing110, if you're taking requests I'd love to see it's stance from the side. :D
ill find my camera today and get a couple more shots of it from the rear front whatever,maybe find somthing else to flex in 2wd on hahah.. gotta finish the rear before i buy parts to build my front driveshaft
well i am sick right now so instead of going out in the heat driving around i just took a couple pics in front of the house .. i cant wait to drop the rear some more it looks goofy with it ass high
these are about 5'6" from camera lens to ground
here is a couple as you can see my brake lines need to be moved or be longer
http://memimage.cardomain.net/member_images/7/web/235000-235999/235498_104_full.jpg
some wall thing that was pretty steep .. its steeper than it looks as you can see the angle of camera
its not all buisness right now ..... im gonna have to baby that front axle till i can actually afford to build up a 60 ... just im me on aim monstrram99
