WHOOO HOOO !!!! Jakes I found on e-Bay came in today!!
ARAMP1
Aviator Extraordinaire
Memphis, TN
I can't wait to see the look on my neighbors faces when I slow down coming into the neighborhood using these!
How exactly do you hook/assemble all this to make it work?
Half our "better" neighborhoods all over the state outlawed those , like they are going to make someone turn around while passing through with a load :rolleyes:.
I like the sound myself :thumb:
They banned the USE of them in certain areas, not having one on your vehicle:rolleyes::rolleyes: They don't expect you to "turn around." They expect you not to use your jake brake in those areas.
Cool! You will need a master switch, a jakes on/off switch, and usually they are wired up where you have to have the throttle pedal in the idle position, clutch engaged before the jakes will activate.
Yeah, I've got a master arming switch (which I'll probably scrap in favor for something like an aircraft toggle), and there's a switch that arms when the throttle pedal is all the way up and one for when the clutch is engaged.
This mod requires straight pipe--no mufflers!!
BBBRRRRRRRRRRRAAAAAAAAAP,
BBBBBBBRRRRRAAAAAAAAP,
BBBBBBBRRRAAAAAP,
BRAP!
Thats awesome.......I like!
If you need some 2 stroke hard parts, let me know. The Engine shop I used to work at has a fairly good stock pile of old Detroit crap.
