trevmountain
Just talked with Jess at high angle driveline today about getting a cv shaft for my K30 long bed. I just bolted on a gear vendors and I am running a 6 inch lift so I figured I would most likely need to get a cv style double cardan to mellow out excessive vibration. He mentioned that sometimes these gear vendors don't work very well on these trucks. Something to do with to much strain where it mounts to the 205 transfer case, to much weight hanging. He was saying if I had a double shaft it wouldn't be a problem. Which makes sense, it takes all the weight strain out of the equation.
Anyway after talking with him I went down to the shop to estimate my angle and length. It's an estimate because the motor is not in the truck right now so the tranny and case are kind of teetering on the cross bar. What I came up with was an angle pitch of right around 12 degree's and a length of about 48 inches.
Just wondering about other's that are running gear vendors in there trucks or K5's and if there's any issues ect...
