I had planned on using my existing NP205 for my doubler setup. After I found out that most shops were going to charge about $800 just for a complete rebuild, then another $100 to have a machine shop enlarge it for the bearing and then the bearing conversion parts were $200 for a total of $1,100 , I opted just to buy one already set up from ORD for $895. If you are rebuilding your own, I would suspect you can get your case machined for around $100 or less. Then you have the kit for $200 and a rebuild kit for everything else for $200. Total if you do it yourself is around $500 or more. But, you have to completely empty out the case so that when the machining is done, you can clean it real good and then completely reassemble it. I decided that my time was worth the money to pay to have it done. I also bought ORD's NP203 rangebox and doubler adapter at the same time.
