I did notice the front axle seemed to be wrapping on that comparison climb in the video. I'm not sure what you can do for that with leaf springs.For some comparison, I have procomp springs, 52s and 56s. No traction bar, and I know both @ashman and I were at 10psi or slightly less on that day.
I think his softer springs might be allowing more wrap in the front which could be contributing to the bounce. He has a rear traction bar.
I will also modulate my brakes when on climbs like that when the truck starts bouncing to help settle it down.
No, he has 37” Cooper STT Pros, while I have the older Geolandar MTs in a 38I did notice the front axle seemed to be wrapping on that comparison climb in the video. I'm not sure what you can do for that with leaf springs.
Are you guys running the same tires?
I was thinking maybe your tires just work a little better for your trucks. Like the tire compound or sidewall stiffness is a better match.No, he has 37” Cooper STT Pros, while I have the older Geolandar MTs in a 38
Leafs work really well with a bypass, especially if they are tuned shocks to your rig.Probably the least painful thing to try is shocks. I have Bilstein 7100 reservoir shocks in the front and they've been good. You can buy off the shelf valving or I think you can have them set up special for you. i assume thats still the case, it has been awhile since I got them.
In hindsight, I wish I would have gotten 2.5" instead of 2.0" shocks. Mostly I think this because of weight of the truck.
I've been tempted to try triple bypass shocks. I've talked to a couple shock companies that say they can work well with leafs. I was thinking I could try them and they'd still have use with a coilover link setup.
For what it's worth, this is what my shackles look like.
I was thinking maybe your tires just work a little better for your trucks. Like the tire compound or sidewall stiffness is a better match.![]()
As much as I've been fighting it, I do think that links are in my future. The problem (other than the cost) is the might-as-well that comes with it. I hate how short the wheelbase is, so I'd like to stretch it, but that means changing the fuel tank... again, plus some fender trimming that I've been dreading for a long time.Front traction bar sounds interesting packaging it with leafs.
ORD has a nice 4 link traction bar kit that comes with coilovers….![]()
You are close to maxing out BYT, it’s only a matter of time until you cut it up or leave it as is and build something else. It stinks but sometimes reality sets in.As much as I've been fighting it, I do think that links are in my future. The problem (other than the cost) is the might-as-well that comes with it. I hate how short the wheelbase is, so I'd like to stretch it, but that means changing the fuel tank... again, plus some fender trimming that I've been dreading for a long time.
Two pages and no boob jokes? What’s happening around here….![]()
