apache
Ive had more Chevy 4wd trucks than I can remember but my 84 K5 has to be the only one had that came with a factory engine oil cooler... so I ask whats the point?? shoulda been a trans cooler. Sure made for a PITA when installing the frame brace to the steering box. Im considering removing it as the lines look a bit used,hate to see it end up like that Cummins with the walmart oil special
. Curious if Id the threaded filter collar will come out the cooler adapter and fit into the block like normal?
