jonathon
I've got a wierd issue...
No matter what I can not put more than 10 gallons of fuel in my blazer without getting insane splash back. I'm pretty sure it's not full either as the guy I bought it from said it was close to empty, but I've not been able to put much in it
What happens is right around 6 gallons I start getting a ton of splash back shutting the pump off, so I stop and wait a bit and usually get a gallon at a time in till it hit's about 8 gallons and then it's maybe .25 of a gallon each shot. It's acting like the air has no where to go but back out the filler neck
What could the cause of this be? I'd like to be able to fill the tank up...
If I have to drop the tank anyways.......
