I'm going to say that the linkage to the t-case is getting loose and not pulling the gears all the way. How I got around it in mine is to pull it into 4low then back to high, that seemed to work. Gotta get under there with a wrench someday...
had that problem too. adjusted linkage and that worked for a few more trips out but eventually I had to rebuild. I found the little teflon pads were shot and one was completely missing. It wore out the fork pretty bad. good time for the sye kit ya always wanted
