why does my hood pop in the rear
jeremywrags
Chino CA
hi all I recently installed a new front clip but now when I close my hood the back sticks up. does that mean that my hinges are bad. I have compared my hinges to others at the junk yard and they don't seem to be any more loose than mine. Or is the hood simply not alligned properly I have messed with it a ton and cannot seem to get it to sit right. Fyi this is on a 1975 k 5 blazer
thanks in advance
If your hood is sticking up in the back your hinges are out of adjustment. You'll need to drop the rear part of the hinge down. Try loosening the bolts on the back of the hinge and push up on the front of the hood, then tighten the bolts back up.
