89 Jimmy. I have had this problem the entire time I’ve owned the truck, about 4.5 years. Whenever it is below about 45 degrees I will go to roll my rear window down and it will move about a 1/2 inch and then quit, and not go up or down, but when I hold the switch in either position, my volt gauge drops down like something is happening, but it isn’t. Usually after I let it sit for 10 mins or so, or literally sit there hitting the switch repeatedly it will eventually roll down and back up at normal speed. So obviously this is an issue in the wintertime. In the summer it works just fine. As far as I know the only “mods” that have been done to any of the wiring to do with the rear window is it’s wired to a different 3 position toggle switch below the dash because the OG stopped working, and the tailgate up/down safety switch has been bypassed. The cable is properly lubed and the motor (when it works) goes at normal speeds. Also I have no issues in any temperatures with my front windows. Any ideas? Going on a family trip this weekend and we all might be taking the J because it is supposed to be snowing at our destination. Would love to fix this issue before I have to load an entire families worth of luggage through the passenger door.
