Jessie James
I must admit, I am a little annoyed that Chevy no longer makes a modern K5. I'd buy one in a heartbeat.
Can we start an internet petition or something?
Let's say you COULD get a 2012 K5 Blazer, what features would you want on it that are not offered on their current trucks?
I was thinking a killer feature would be to have 4 little motors in the bed walls. After you unbolt the top, the motors would lift the cap up about 1" to 2" or so, and then you could insert/attach a flange of some sort under the edge of the cap which had an anchor that stuck out to the side. Then you could either put some straps on it and lift the cap off, or you could have some "feet" like what are used on pickup RV caps that would stand on the ground, maybe that were all attached to each other for strength, and then you just drive away.
