Exactly, AGMs are a little less forgiving, but they are worth it. The key, is the voltage measurement at the battery.
For long battery life, you are concerned with what the battery sees, not what the truck does.
If an accurate meter at the battery never goes over 14.5 for very long, it does not matter to the battery what the gauge in the dash says.
If the gauge in the dash is different from the rest of the readings in the truck with a good meter, I would suspect the gauge in the dash.
However, you start seeing different voltages in different parts of the truck, you need to check your grounds and power connections.
A tenth of a volt is not a problem, but if its a 1/2 volt or better, then you need to check.
