Jesse Jaymes
Registered Member
Seems my driver's side hub keeps moving into the Locked position. I keep changing it to Free and then a few days later I will check it and it says Lock. WTF? Anyone tell me whats broken or what needs fixed?
the end of the axleshaft is rubbing on the hub body and turning the knob. have you swapped shafts recently and forgot to put the seal on the new shaft. that would let the axle shaft slide out.
if not your options are limited. grind down the end of the axle shaft or swap to a different hub that doesn't rub. the cheapest being to grind the end of the shaft.
Do you have a prankster around?
