Why is my replacement balancer bigger
pudd
Newbie
Tennessee
Why is my replacement harmonic balancer bigger than the original. Is this normal or is Auto Zone handing out the wrong parts again.
Depends on application . I just replaced one , and had to take off the factory timing tab , and use a new one to match the balancer .
Look at replacements on summit or jegs , they list a couple sizes so you can match what you have .
It is on a 1989 350 throttle body injected engine the replacment balancer looks like it is the size used on the carbureted engine. Any idea?
Just measure your old one , and get a new one that size . Its not hard at all . Call a speed shop , or engine builder , or look online .
Most parts stores are good for the stuff we need a lot , like spark plugs , bearings ,brakes etc . But I would not buy engine internals , carbs , balancers , or any stuff like that there .
BTW , there are several sizes available I can rattle off , 6.25 , 6.75 , 7 ( not common ) , and 8 inch .
And there is internal , and external balanced . Yours is the first type if its stock .
we've been over it before, pretty certain all Single piece rear main motors are externally balanced. If thats correct, just replacing the balancer could be a bad choice. I mean it could run forever or vibrate like mad and wear out bearings in a week.
One piece rear main motors only use a weight on the flywheel or flexplate.
The original balancer is a 6" and the replacement is a 8" they are both internally balanced. The 8" fits ok and does not affect the timing pointer. all is well. I was told as long as both balancers are internal balancers it will work.
