K K5_Fla 1/2 ton status Joined Jan 17, 2010 Posts 489 Reaction score 0 Location FLORIDA Jul 31, 2011 #21 no backfire
Confedneck 3/4 ton status Joined Nov 1, 2002 Posts 5,235 Reaction score 2 Location Lehigh Acres, Florida Jul 31, 2011 #22 have you tried swapping the fuel pump relay for a new, quality unit?
diablo1 1/2 ton status Joined Sep 23, 2007 Posts 163 Reaction score 0 Location colorado Jul 31, 2011 #23 Maybe your fuel is starting to boil in the carb form the heat from the manifold.
YZEATER 1/2 ton status Joined Jan 21, 2005 Posts 2,358 Reaction score 0 Location TARENTUM, PA Jul 31, 2011 #24 do you have a return line going back to the tank?
K K5_Fla 1/2 ton status Joined Jan 17, 2010 Posts 489 Reaction score 0 Location FLORIDA Jul 31, 2011 #25 have a return line ... all lines are new. The one line that goes from regualtor to carb is also wrapped with heat sheild
Confedneck 3/4 ton status Joined Nov 1, 2002 Posts 5,235 Reaction score 2 Location Lehigh Acres, Florida Jul 31, 2011 #26 where in florida are you?
Polski-Chevy 1/2 ton status Joined Jul 21, 2008 Posts 523 Reaction score 0 Location Cumberland, Indiana Jul 31, 2011 #27 Vacuum leak?
pblaze725 build bash rebuild Premium GMOTM Winner Joined May 28, 2007 Posts 4,438 Reaction score 980 Location San Carlos, Ca Aug 1, 2011 #28 ...Do you have a manual fuel pump? I still think the fuel pump is the issue.It's going but not yet gone. When it happened to me my bro-in-law told me it was the pump & I didn't want to believe him. Later he "told me so".
K K5_Fla 1/2 ton status Joined Jan 17, 2010 Posts 489 Reaction score 0 Location FLORIDA Aug 1, 2011 #29 elec pump in the tank. Fuel Pump, sender, regulator, fuel filter, fuel lines... all new.
Confedneck 3/4 ton status Joined Nov 1, 2002 Posts 5,235 Reaction score 2 Location Lehigh Acres, Florida Aug 1, 2011 #30 K5, where in florida? BTW, new does NOT mean good all the time...
K K5_Fla 1/2 ton status Joined Jan 17, 2010 Posts 489 Reaction score 0 Location FLORIDA Aug 1, 2011 #31 near Jax
Confedneck 3/4 ton status Joined Nov 1, 2002 Posts 5,235 Reaction score 2 Location Lehigh Acres, Florida Aug 1, 2011 #32 shiiiit, nvm, if you were close, i'd come help... anyhow. have you checked for voltage at the pump? pressure?
K K5_Fla 1/2 ton status Joined Jan 17, 2010 Posts 489 Reaction score 0 Location FLORIDA Aug 1, 2011 #33 Yes, pressure is a perfect 5psi.... I'm going to drive it some tomorrow... I think I just may of had some bad gas in the tank.
