Excuse a noob question, but me and a buddy were going through the engine compartment of his newly bought 6.2L Jimmy and found this green wire loose and tied up around the pink solenoid wire. I don't have a wiring chart available where I am, but isn't this for the temp gage? And shouldn't it be fastened on the right nut in the picture, opposite the solenoid mount - which seems to be missing part of the mounting clip for it?
I might also add that, no, the temp gage doesn't work, even though the sender unit in the block (left in pic) does... Didn't wanna mess with the wire since I'm not sure, but figured that some of you could probably answer this in your sleep.
Alternate link for non-paying members: http://img444.imageshack.us/img444/8324/p6300297xh5.jpg
), maybe it's hard to tell from the picture, but it is connected properly to ground. I've messed with those a fair share of times, but never had a reason to pull the temp gage ground, so that's why I was unsure if that green cable was really it. Didn't wanna give the wrong advice seeing as how it's not my truck and all.
You live and you learn.
