hunterguy86 said:I could be wrong here but isnt a winch multimount system only as strong as the pin holding the winch in place. Or am i picturing the mounting system wrong in my head? Im seeing it as the winch mounted to a reciever just like a reciver hitch would be. Seems to me that the winch is just as strong as the pin holding it in place.
Actually, the weak point becomes the tube on the winch plate. The pin is in double shear and 5/8" in diameter whereas that tube is in tension and has only about twice the cross sectional area of the pin. If you use a solid tube then the weak point becomes the receiver tube.
My multimount winch is a MileMarker E12000 bolted to a piece of 1/2" plate surrounded by 2x1/4 angle iron welded to a 20" long piece of 2"ID 1/4 box steel. It weighs in excess of 150lbs. I can only carry it 50-60' before I get tired. It's a chore to move when it's a muddy walk. It's cake to carry for two people if one of them isn't a wimp. http://www.wrath.com/vehicles/84k10/winchrelated/winch_082304.jpg
I think the ultimate for mud running is a hydraulic winch on the front and then a multimount electric winch that has a home in the bed but can be pulled off to be put on the front or sides (roll yourself back over). Running just one winch in the bed is satisfactory if you've got a PTO winch.
