kernel87
Registered Member
I've got a fullsize chevy with a dana 60 front with high steer. I'm using the factory steering box with a swapped in sector shaft, late model dodge pitman arm and OTT Industries steering arms. When turning the steering wheel, at full "lock" it doesn't even come close to the stops on the knuckle. It's equal both ways, so the drag link is adjusted. With it unhooked it will turn all the way to the stops, so it's not binding. What gives?
