Big6ft6
My original repair thread is in the injection section. But now that it is fixed and I don't know why it is fixed, I thought I might get some more ideas here.
A month or so ago I fired up my 91 350 TBI k2500 and oil pressure didn't register on the dash gauge. It was a REALLY cold (single digit) morning when this first occured. After a few minutes it would just barely register on the gauge and if I increased rpm it would drop back to zero
. Eventually after 6 minutes it would register about 10psi and not move at all with rpm. Before this my oil pressure gauge regularly would bury the needle and would fluctuate wildly at different rpm. So I assumed I had the common bad sender and it had just gotten worse now and was not registering, but secretly I was worried. I drove it this way maybe 5 or 6 times, nervously waiting for pressure to register on the dash gauge, before finally my concern got the better of me and I replaced the sender. I started the truck expecting full oil pressure...but instead found no change
Now I was worried. So I pulled the pass. valve cover to watch for oil during a cold start. There was no oil at the pushrods until about 5 minutes after a cold start (See video in original post). The oil showed up at the rockers about the same time the dash gauge would begin to register some pressue. I thought maybe it was just the cold oil taking time to get up to the lifter and through the push rods so I picked up an oil pressure test kit and fitted the gauge in the plug hole just above the filter to test pressure there and started the truck again from cold...ZERO pressure
I immediately shut the truck down.
I was really bummed out, figured I had clogged or messed up oil pick up. I vaguely remembered this all starting not long after my last oil/filter change (I don't drive the truck often) so I figured, what the heck, I'll change oil and filter. I also stuck a piece of a wire clothes hanger with a little hook on the end up int he oil pan and blindly fished around after the oil was drained...nothing of note came out not even sure where I was sticking that thing. After the the oil/filter change I started the truck and low and behold instant gauge pressure at the dash and 45 psi on the test gauge
Any ideas what could've happened? How could the filter have caused this? Wouldn't the filter bypass have allowed oil pressure to the engine even if the filter was completely blocked? What the heck?
I immediately shut the truck down.I was really bummed out, figured I had clogged or messed up oil pick up. I vaguely remembered this all starting not long after my last oil/filter change (I don't drive the truck often) so I figured, what the heck, I'll change oil and filter. I also stuck a piece of a wire clothes hanger with a little hook on the end up int he oil pan and blindly fished around after the oil was drained...nothing of note came out not even sure where I was sticking that thing. After the the oil/filter change I started the truck and low and behold instant gauge pressure at the dash and 45 psi on the test gauge
