olbattlebuggy
Registered Member
i just put a 6" rough country lift on my k5 and now have a wicked vibration in the drive train that wasn't their before the lift went in. what would be the most likely culprit, u-joint ?
you dont think i could have messed up the R/P by leaving driveshaft connected during spring swap do you ?well if the angles are right, then yes the next place to look would be the ujoints. I just replaced mine in the past couple of weeks, haha.
YES!Do you think ill mess anything up in the drivetrain if I go wheeling on it this weekend?
Find the problem before you take it anywhere. U-joints may be in a bind or bad, and they could come apart if you take it wheeling without fixing it.
..Dropped the transfer case crossmember 1" and corrected driveline angle to solve vibration troubles!! Good luck solving the problem!!
