the excuse
sometimes when i press the brakes the turn signals indicators in the dash will light up and the front lights will go on too. the lights arent blinking they just light up and go off when i let off the brake. if i pull out the emergency flashers button then put it back in the problem is fixed, untill some random time when it decides to start again. what is wrong with it? it has also developed a new problem when going over bumps in the dirt sometimes the right turn indicator will start to light up but in very rapid blinks as if a wire was rubbing to make it light up. the blinks almost go with the bumps, every shake causes it to light up. my turn signal lever is cracked inside but i cant see how this has to do with the brake lights causeing the turn signals to go off. would fixing the turnsignal lever fix my problem? /forums/images/graemlins/dunno.gif
