3car
I'm thinking about getting a set of tuff country 3" springs for a suburban i picked up. will i need a raised steering arm?
It all depends on what you want to do with it.I'm thinking about getting a set of tuff country 3" springs for a suburban i picked up. will i need a raised steering arm?
Pardon my ignorance. When you say "steering arm" are you referring to a pitman arm, steering damper or what? Thanks.
jor
Oh yea, thanks. Then I guess the OP's question was should he get a steering arm that adjusts for his lift. I have the same question. I have a 4" lift on my Suburban but am using the stock steering arm. I recently changed over to a 4.10 ratio on 8-lug axles and replaced all the ball joints and bushings. I used the stock steering arm and drag link as it worked fine before on both road and off-road driving. I also reinstalled the sway bar although from another discussion I think I could just as well omitted it. Anyhow, here's a photo of my steering arm. Hey sweettk, would you mind posting a photo of your steering arm. Thanks.
jor
I have 3" springs on the front of my 78 k5 and tried a raised steering arm. I ended up putting the original steering arm back on and using a dropped pitman arm. I like the dropped pitman arm much better. I think it was a 2" drop. I think the steering arm may have worked better if I had more lift.
What is it that you didn't like about the raised steering arm? Thanks.
jor
I have a 6" lift on mine and i didnt put the steering arm on at first. WOW did i not have a turning radius. and OMG it took me 3 days and 2 cans of pb blaster to get that f-n thing off. O I FORGOT TO MENTION THE SLEDGE HAMMER ALSO
. after several days of frustration they came off.He probably had a 4" raised arm on a 2" lifted truck
Since he liked the 2" droped pitman arm.
There is I believe a 2.5" raised arm, I had one.I had a 4" arm on a 3" lift. I mostly was driving on the street and it felt like the blazer would kinda sway sideways a little with every bump that I hit going down the highway. I dont feel that with the 2" dropped pitman arm. I didn't know that there was anything other than a 4" raised steering arm.
Well steering arms are in different sizes, I had a 2" raised arm for my 2.5" lift, you want to match your lift.
I had a 73 blazer with a 1.5" lift and off road I still could feel the bump steer with the stock arm.
On the road I never felt it because it doesn't flex enough to feel it.
