will 31-10.50 BFG AT's fit on a stock 92 S-10 4wd?
Re: will 31-10.50 BFG AT\'s fit on a stock 92 S-10 4wd?
Nope. I've got a '91 and 30x9.50's is all I could stuff under it. Even then they'll slightly rub the rear of the front wheelwells at full stuff unless you crank up the torsion bars and raise the rear to match. /forums/images/graemlins/frown.gif
I heard even with cutout flares you can only go up to 31's.
My wifes 91 is gettin 31's(and flares). I wanted to go 33's.
Nope....we put that size on a '91 with a 3" body lift and they fit fine...but wouldnt fit stock....
I hvae an 88 s-10 blazer with a three inch body lift and i fit 30's tight but i dont rub. My friend had a same body style s-10 with 6" lift and he fit 33's with cut outs witch sucks lol
I've got a 92 S10 4x4 with 31x10.50 on it and they do rub on the rear of the wheel well in the front, they fit well on the back though (not much suspension travel though), oh ya that's with the torsion bars cranked and add a leaf(s) on the rear, I'm thinking of going with 30x9.50
My 89 blazer has 32's with 3" body lift and trimmed fenders still occasionally rubs
I did it NO PROBLEM! Check out my article on how I trimmed my fenders. The 31x10.5x15s that I am running have only rubbed on the front a VERY FEW times and that was minimal... But my shocks were SHOT, too. They've never rubbed on the back. I am very pleased and wouldn't think twice about doing it again. The article can be found under "Technical Articles" on my website listed in my sig.
I run 33x12.50's on my 89 S10.
3in Body Lift
T-Bars Tweeked/Shackles
A Little Triming /forums/images/graemlins/thumb.gif
just put a set of 31-10.50's on my wifes STOCK 91 S-10. tell me they don't fit!! just got to use a big hammer!!
Not all of us have had the fenders removed courtesy of the road salt crews. /forums/images/graemlins/wink.gif
< got 30x9.5x15s on a stock 99 s-blazer 4 door 4x2 they rub at full lock in reverse only... go figure they fit
I've got 30's on my '91, but 31's won't fit it without hitting. At least true 31's... /forums/images/graemlins/wink.gif Some tires are marked 31 on the sidewall, but can actually be as small as 30.2 inches tall. /forums/images/graemlins/shocked.gif
well, you called that right!! wasn't much to hammer over. still rub the rocker rails in the front now and then
