Will a 10bolt yoke and D60 Yoke Swap?
BigCountryx
Gonzales, LA
Just what the title asks, Will a standard D60 Yoke work on a 10 bolt and vise versa? (Front axles)
Are the splines on the pinion and the diameter of the yoke where it meets the pinion seal the same?
The pinion diameters are the same according to Richmond. They are both 1.626". But the 10 bolt has a 30 spline pinion whereas the 60 has a 29. You could try and see if they will interchange. One area where you'll run into a problem is the seal area.
