Metal Twister
Will a 43 gallon Burb fuel tank fit in a K5 Blazer frame with out modifications to the tank? I have a 10 lift on the Blazer so I'm way above the the rear diff but curious if its been done?
An idea, you could cut the floor and set the tank actually inside the cab. Iv seen it done that way to avoid the diff clearance problems. I wouldn't do that on a classy k5, but a straight mud truck sure why not.
