Will a dropin bedliner fit?
19blazer78
Registered Member
St. Marys, West Virginia
I think I know the answer.... I know i'll need to cut the bulkhead section out but will it fit over the wheelwells and everything the way it suposed to?
The liner is from a 87 longbed, so I should have some "wiggle" room if it should work. The guy is asking $45 for it
Since a pick up tailgate will fit a K5 I would think a bedliner would also. That said you'll have to cut both ends since each end to wheelwell spacing is different. Also, the bedliner will not have a molded spot for the fuel filler cover that's in the right rear of the K5 bed so it probably wont lay "flat" like it should.
I vaguely recall Blazer wheelwells not being the same as pickup, but I can't recall which is bigger, i.e. if the bedliner would like droop over empty space or if it wouldn't go over the wheelwells.
With all the chopping you'd hafta do I don't see it fitting *nicely*. Up to you to decide if that's okay.
-- A
Could someone with a truck (prefer a bodystyle same as a 87) please take some mesurements for me?
I need the size of the inner wheelwells....
The length from the front to back at the floor
The width from the wall
And the hight from the floor to the top of the well
