B
Bohemian
Guest
SBC 350 4 Barrel, GM Cast Iron Spread Bore Intake Manifold.
I seem to remember back in the day that if that exhaust crossover in these old cast iron spread bore SBC Intake Manifold's was plugged up with carbon it could cause blowby...
I also seem to remember having to knock the 4 rivits out of that steel pan on the bottom of the intake in order to cleanup all the carbon there because it causes a carburetor heat soak condition that causes hard starts after engine is warmed up, but engine otherwise starts first try when cold.
Any of this sound familiar to any of you all?
thanks in advance.
thanks in advance.
