Some of the clips are in the wrong spot from early to late ( easily removed , but not added ) , and the dash bezel sticks out past the pad if you use an older pad with new bezel .
You can easily put a whole newer setup ( dash , bezel , gauges , complete wiring ) into older though , if you remove a couple clips .
