I found an 87 truck with hydroboost and diesel engine.I want to swap the hydroboost into my 89 burb.Will the power steering pump brackets work on my 350?Thanks
pump just pull the pulley off and 3-4 bolts to bracket then swap to your brackets and press the pulley back on with puller/press tool kit for this job.
No need to swap the pump. a single return (stock) pump will just fine, Tee the return lines from the hydrobooster and gear box into one line and connect to pump like normal. Would be a good time to add a power steering filter too.
