Will EGR affect performance?
zach78k5
I just installed a holley projection system and intake to go with it. It came with an EGR blockoff plate. If I use this should I just put a plug on the TBI unit. I assume my emissions may be affected but will drivability be affected?
EGR doesn't hurt performance and helps fuel economy. When you stomp it to the floor, all EGR flow is off anyway. I'd keep it if it works correctly.
mine is bent though. I was going to use the blockoff and buy a new one down the road. should I just use a hose plug on the carb?
get rid of it if you dont ahve inspections or testing there, blocking it off is not going to hurt or help anything- same with having it, not on these engines anyways, later on they became electronic controlled and in some cases unplugging them might change how they run
i was told by toyota board that disconnecting EGR hose on the 22RE engines changes its timing somehow, i dunno, i think they are smoking something funny though, im leaving mine plugged off,
thanks, that was the answer i was looking for. my setup at this point is far from stock i suppose. I could see that blocking it off with all the other vaccuums might be a problem but they are all gone because of the projection system. I will just block that sucker off.
[ QUOTE ]
[/ QUOTE ]
The EGR is supposed to introduce a little "Exaust Gas" (Recircuilation) into the intake, it keeps chamber temps down. This in turn keeps NOx down. Like tim said, doesn't hurt anything except the envrionment.
The new chevy's don't have 'em stock, guess they are getting good enough they don't need 'em.
