Will these door panels work
sky56
Registered Member
Chicago, IL
My door panels arent in the best of shape and ive found a set local to me that came off a 78 scottsdale p/u. theyre black so the color works but im curious if these will work in my 75 blazer ? if i have to do so some slight adjusting to make them fit thats cool as long as they would work. Any help would be much appreciated. For $50 it would suck to pass them up.
There should be no issue using those panels in your 75. Although the trim may be a bit different from yours, they should mount the same way.
