Will these rims fit? 08 H3 to 91 K5
Its actually opposite. If you try to fit silverado wheels on a h3/colorado you have to bore out the hub. You should be able to run them. Test fit one just to be sure.
most ifs front end stuff uses deeper backspace rims.
so test fit would be best. and check for tie rod end clearence to rim.
Cool, Thanks guys:waytogo:.. I like the way these rims look but the rim width is only 7.5?(if i researched correctly) One thing that confuses me is the rim width. So do the tires have to be the exact same rim width?
