xsmokey11499x
They are 33x12.5 r15.
my truck is an 87 gmc sierra 1500. 2wd. stock suspension.
yes if you cut open the fenders or dont ever turn .
otherwise nope you need lift of some kind.
all over as its a wide / fat tire in a 2wd suspension and also stuffed in a fender hole to small for that setup.
you can test fit 1 and turn the wheel to see were for your best option .
I don't know what size wheels you have but I had my 33x12.5x15 on 8" wide wheels and they clear fine.it seemed like I had about ~4 inches or so before the inner fender
Yes and the narrower the rim, the closer the tire is to the middle which makes it clear the fenders.Isn't the backspacing of the rim, the most important part?
