Will these wheels fit my 1991 K5
RJB44
Northern Virginia
A guy has a set of 16 inch wheels with center caps off a 1994 Blazer. Just curious if they will fit on my 1991 K5. See photo of center cap.
they should clear, but you need the double thread lug nuts off ebay to make em work.
Too much backspacing. The wheels will be tucked in too far and look funny. May even hit the tie rod or something. :dunno:
They will fit
You have to get conversion external lug nuts from an parts store like napa where the internal threads are the 7/16 and the outer are threaded for the plastic nuts that hold the cap on I'll try to get some part numbers if yer want
I beleive hes more talking about the wheels themselves fitting and only included a pic of the caps.
Thanks for the info on the wheels. Will these center caps fit a set of 15 X 10 Cragar Soft 8 Black Wheels (3975160)?
should with the lug nuts mentioned
