will this work for 8lug swap?
misfit
south central wa state
ill be swapping eevrything from spindles out from a 76 3/4 dana44 onto my 74 1/2 d44. everything will work right? even my stock calipers? im pretty sure i have to change spindles though.....
Everything should work... Double check the spindles beside each other.. Also, check the 74 and see if the shafts have the 297-x u-joints. If not, use the 76 shafts...... 74 was the first year for the 297's, but you never know with GM....
Other than that, sounds good to me!
Mike - <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
