Will Toyota Tacoma 6 lugs fit my CK?
Jsa89
Registered Member
Fort Worth, Tx
Found some 15x10 steel wheels that came off of 02 Toyota Tacoma. They're six lug? I've got factory axles
I don't know about newer toyotas, but older ones are the same..... just need to watch the center hole size, toy rims might be to small, be carful sometimes it might seem like it will fit but the wheel doesn't sit flush to the axle flange cause the center hole is slightly too small
Yes,Toyota uses the GM 6 0n 5.5 pattern. I don't know if that has changed more recently,but that was always true from way back to the '60s
Yeah,factory Toyota wheels in more recent years will have too much backspacing,like about anything factory these days.
well since the op is asking about 15x10's, they are aftermarket wheels. should fit just watch the backspacing. tie rods will hit if too much.
I don't think they will fit.
I believe the '02 toyota lug pattern is 6 x 6" and the GM is 6 x 5.5"
Thanks for the heads up, I picked them up today and had my Dunlop mud runners (35's) mounted and balanced, they worked perfect. I found a craigslist treasure ( 100$ for 4 15x10 black eight hole steelies). I appreciate the info
For 100$ I figured it was worth a try, lucked out, maybe I should go buy a lotto ticket. Again, thanks for the replies, this is a great website with tons of info....and great people...
I sold my stock steel toyo wheels for $25. intended to make them my snow tires but by the time I got around to that I sold the truck.
