pauly383k10 said:Hi-Jack hehe ,
Can someone explain why Ramsey doesn't want me running rope on my 12,000 pounder ?
Everyone I talk to say to anyway , and I would prefer to do it too .
If you have an 8274, it doesnt matter what heat rating the rope has. Additionally, because of the factory hole in the drum, you can pretty easily buy bare rope from a marine supply place and make your own winch rope out of it. Might save some coin...
Leper said:To "double rig", if you mean using a snatch block, each cable would only see half of the load.
jms said:DPI, I like your sig line...![]()
fireplug said:I've been researching the stuff for a while. From what I understand the fraying is normal and doesn't affect the strength rating (this is the same with climbing rope so I trust the source). Though the protective sleeves are a good idea. Apparently the heat issue is for most makes of winches during powering out the line. Personally I never power out only in so it isn't a consideration..
