winch deal
habitatxskate
emerson nj
someone should pick it up, harbor freight sends me a coupon booklet like once a week or so if i see anything else that is worth mentioning i will..
[FONT=Arial, Helvetica, sans-serif] 10,000 LB. CAPACITY ELECTRIC WINCH WITH AUTOMATIC BRAKE AND ROLLER FAIRLEAD[/FONT]
[FONT=Arial, Helvetica, sans-serif][/FONT]
[FONT=Arial, Helvetica, sans-serif] Planetary gearing for fast line speed and sure hold. Three stage system with automatic load-holding brake. [/FONT]
  • [FONT=Arial, Helvetica, sans-serif]
    [*]Power in/out
    [*]Remote hand control switch with 12 ft. cord
    [*]Automatic load-holding brake
    [*]Roller fairlead smoothly guides wire in and out of the winch
    [*]Line speed (in feet per minute): 6.56 FPM @ 2000 lbs., 6.23 FPM @ 4000 lbs., 4.92 FPM @ 6000 lbs., 4.26 FPM @ 8000 lbs., 3.28 FPM @ 10,000 lbs.
    [/FONT]
[FONT=Arial, Helvetica, sans-serif][/FONT] [FONT=Arial, Helvetica, sans-serif] 12 volt, 4.8 HP, Drum diameter: 2.64'', Gear ratio: 294 :1, Cable size: 3/8'' x 100 ft.; Bolt pattern: 10'' x 4.5'', Overall dimensions: 21.9'' L x 6'' W x 6.8'' H, Weight: 84 lbs. [/FONT]
coupon
winch
http://www.harborfreightusa.com/usa/itemdisplay/displayItem.do?itemid=91905
Forgot to mention the 4" grinder
[FONT=Arial, Helvetica, sans-serif] 4" ANGLE GRINDER[/FONT]
[FONT=Arial, Helvetica, sans-serif] Heavy duty motor powers this grinder up to 11,100 RPM. [/FONT]
    [*]Ball and needle bearing construction for smooth running with less heat
    [*]Aluminum gear housing keeps tool weight down to 4-1/2 lbs.
    [*]Recessed spindle lock button
    [*]Easy access brushes
    [*]Double insulated
    [*]UL listed
    [/FONT]
[FONT=Arial, Helvetica, sans-serif][/FONT] [FONT=Arial, Helvetica, sans-serif] Comes with 4'' grinding wheel; 110V, 60 Hz, single phase, 570 watts, 4.5 amps; 5/8'' x 11 spindle with 7/8'' arbor; Shipping weight: 5 lbs. [/FONT]
coupon
source
http://www.harborfreightusa.com/usa/itemdisplay/displayItem.do?itemid=91222
