ok so now ryoken has helped me figure out the wiring for my winch setup...
also explained other things to me..
so i have a pic added... it is the box that the batteries will be in and this covers the winch that is between the frame rails. now this box will sit up 1" higher...
but the way it is set is this...
batteries facing each other... 3/0 cable connecting them to the winch...
what i need to know of where would you mount.. would be this..
i need to pount the dual battery selector switch, anl 600A fuse and the 4 relay pack off of the winch....
now originally i thought i would put them behind the batteries but didnt think it was going to be that tight... as it is...
so...
should i mount all of them on the inside of the front.. so from your point of view you will not see them... or put them to the left or right side?
i think this is really a non thinking thing.. but trying to get some opinions.. and yes i am over thinking this and over complicating it...
as you can see my wires are long enough to do anything..
the ground wire will go from the batteries and into the bed.... no big deal..
the hot wire backwards from the batteries to the fuse to the switch.. so i kinda want the switch in an easy to reach place (understanding ryoken explained that you do not switch the switch while truck is running.. so if i think im gonna get stuck.. switch over to it ahead of time...
so...
