winch help..pto...please
twoslo4five0
3/4 ton status
Living in a dump, VA
I need to get a winch for my rig...i have a np 205 out of an 80 jimmy..what do i need to use this as a pto drive..i know i need the winch and what elce...were can i buy a pto winch...what are the positives of having a pto with...are they better than an electric...are they cheaper than an eletric..i know nothing about pto and how it works...and advice would be helpfull...
If you're concerned about price, you want an electric winch.
PTO winches tend to be much larger, like on a tow truck or a 2 1/2 ton military truck, and pricier, plus much more hassle to mount.
-- A
Its my understanding that a pto has to have the motor running. Maybe I'm wrong, but it would suck to go through all the work of mounting it and not be able to use it with the motor off.
An electric winch can still be used with the motor off. Not for very long with the amp draw, but for a little while.
If you do any muddin and have happened upon a pretty deep hole, I've had friends shut down thier trucks to keep from sucking mudd into the intake. Probably saved the motor.
In an instance like this a PTO would be useless.
Just my 2 cents
plus if your truck dies, and it won't start, then you have no winch. they will pull a hole out of the ground,but theres to many times when your stuck that your truck is dead for some reason or another.and your stuck without a winch.
i had a friend who had one and it would pick his truck up off the ground, he had a nylon stap on a big limb in his yard with a snatch block and we used it to pull motors or trucks up so we could put stands under it. he broke several shafts tho not the drive shaft to the wrench, the one that is the spool, it would break about 6 inches in, right before it gets to the spool.
but its to many situations where you can wind up without your winch, same thing with the ones that run off your power steerin pump if truck not running no winch....i'd go with the biggest electric winch i could afford and two super batteries !!
On the other hand you can't use an electric winch under water or mud. So alot depends on what you use your truck for. If money permits I usually run one of both on a truck used in mud or deep water. HYD on the front and electric on the rear. If mostly rocks, then this really doesn't apply
My winch has a sealed motor I bet it would work underwater.
Ira
