What are your reasons for wanting a winch if I may ask? Do you actually need one?
Hmm, sounds like someone who has never owned one......
Every truck and Jeep I have ever owned has had a winch on it.
In my case, they were all PTOs
Nothing against electrics, I used to help build and install them, but I like engine power.
Everybody I used to hunt with either had a winch or wanted one. Today, not so much, due to increased age, cell phones, and improved roads.
As long as they can call me..............
In my case at this point in my life, my winch gets more or less used in this fashion:
Pulling myself out, 30%. I have a
good truck.....
Pulling other people out, 40% They don't......
Other uses, 30%. Moving things that won't move otherwise, mostly.
I have pulled dead trucks onto trailers, winched big gensets into sheds and a big lathe into my shed. I have aimed trees in the direction I wanted them to fall when cutting them down.
I have done this three times this year.
And I may have to do it this weekend.
Hoisted dead deer, pulled engines out of trucks, tightened fence wire when putting up fences, straightened things, bent things, torn down billboards and buildings, pulled wells, and picked up the front end of my truck to change a tire.
I have also hoisted large antennas up on towers, lowered them, and lowered a 600lb radar unit off a 200 foot tower.
I suppose if you live in the city, never go offroad, then the uses are limited.
But, then so is the use of 4wd.
A winch is a tool. How much use you get out of it, depends on how creative you are.
I was in my truck with the plant mechanic many years ago. We had a trailer behind us, and were going to buy a used rear end out of a tour bus.
Front end of the bus was totaled, but the rear end was good, and we had a big F750 that the input seal had failed and burned it up.
When we got to the junkyard, the guy said he could not get to the rear end right then.
It was backed up to a fence, the front end was blocked by a semi, and he needed to get behind it with his big forklift to pick it up.
There was a big live oak about 80 feet away from it at right angles to the rear end.
We needed that part.
Our truck needed to roll the next morning.
I asked the guy if he was going to use anything else off the bus.
He said, no, it was going to scrap.
I drove the front end of my truck hard up against the tree with the winch fairlead just clear.
Took my cable over to the bus and hooked it to the frame just above the rear wheels.
Junkyard owner said you are not going to do what you think you are.
I knew my winch, I just smiled.
Put the winch in gear, slid the entire back end of the bus sideways through the dirt until it was clear of the fence.
The dirt piled up over the tires on my side, one of the tires on the other slid off the rim, but he was able to get the rear end out.
As we were leaving with the rear end, the junkyard owner came over and offered me $1000 for my winch.
I wound up selling him a new one for more than that
No way he was getting
my winch...
