Winch mount
Cucv_M1008
Cthulhu Forever
Pendleton, Oregon
Yes my truck is not running but that does not mean I can't buy other things for it. Last weekend I went to the Portland swap meet and I picked up a @engineered_vintage winch mount for my k30. It's pretty stout and I'm impressed with the build quality. I can't wait to install it. I have two used smittybilt 12k winches I'm not sure which one I'm gonna use.
X2o is supposed to be better overall. The xrc series parts are getting old and not as easy to get.
I was on a trail run earlier this year and a Jeep was winching with steel cable. It's been so long since I've been around the stuff, I forgot how much I dislike it. The popping and twanging noises that line was making was scary!
@Cucv_M1008, you can hit up @swettysblazer (4x Store) for winchline. He has great pricing!
Be forewarned, good synthetic line is expensive. I like the versions that have some sort of integrated covering to protect them from fraying.
My favorite so far is Trail Gear Duraline Exoshield. https://www.summitracing.com/parts/tgi-303417 It seems like Trail Gear is phasing it out, unfortunately. It has been a great line. The only problem I had was that I purchased a length too long to fit well on my winch. Because it has the extra covering, it stacks up quicker on the drum.
I would like to try a line by Masterpull, but they're out of stock. https://www.masterpull.com/superline-xd-synthetic-winch-line/ I know they make really good stuff.
The line I just bought thru @swettysblazer is by Bubba Rope and I haven't had a chance to try it out yet. https://www.bubbarope.com/winch-lines/80-foot-synthetic-winch-line I like that it has the "Gator-ize® vinyl armor". I also like the red marks that give you some indication of length. Plus it's made in the USA. And it comes with a soft shackle.
One of the things I look for is the extra heat shield at the end attached to the drum. Every synthetic line I've pulled off after heavy use, has obvious signs of heat damage. I don't think it's a complete deal breaker, but it definitely makes the line weaker near the drum because it gets brittle. If you don't use your winch heavily, it's probably less of a concern. But it is one less worry if you are using it.
