Window Size
kgblazerfive
keymaster
Hooper, Utah 84315
Does anybody know the size difference between a side rear Suburban window and a Blazer window. The fronts of the window looks to be the same, the Suburban has a different back. Looks like I may have a new project to do :rolleyes:
Well got a set of Blazer windows and they are the same size height wize Burbs are longer but not by much so I found my after Blazer Bash project :D
So are you planning to put a set of sliders in the rear? I knew that height was basically the same, but the length is the difference. At least that's what my buddy said when he tried to use the Blazer windows in his Burb.
Yup going to build a insert to weld, screw, somehow attach to the body to fill in the hole and give a place for the window to attach to.
I see. I have put those windows in and out of my Blazer, so I know a few tricks to getting them to seat and seal. If you need any advice or help when you get to that point, let me know and I can tell you or come up.
