So I'm back to messing around with getting my windshield frame prepped to weld up (full top conversion). A stock windshield opening is 23.5" from pinch weld to pinch weld. When I set my upper frame in place on the posts (with alignment dowels to hold it) I've got about a 1/8" gap all the way around. As a novice welder I have no idea if this is ok (fillable) or too much. Can this be welded as is? If not, options?
Since there's a rubber gasket around the glass is there enough fudge factor to push the posts flush and weld them (taking the opening from 23.5" to 23.25")? Am I worrying too much about getting the measurement perfect?
