Windshield washer stopped working (91 Jimmy)
JME
Registered Member
Chesapeake, VA
All of a sudden my windshield washer stopped working. Windshield wipers work perfectly, they even work when I attempt to wash the windows although no fluid comes out. Multimeter confirms no power is getting to the pump. CB is good (I assume it's the same CB for the windshield wipers and washer fluid pump). I'm thinking it's the switch, any thought? Thanks in advance.
Not sure how to test for power at the switch. There's a red wire that gets power when the key is turned on.
Get a wiring diagram and find the pump wire (in a chilton) then turn key on and check it
according to my haynes its the pink wire but you have a jimmy so dont know if they are the same
Helps a lot thanks. I took another look and the wire is pink and not red. Put the multimeter on the pink wire and it's hot when the key is on.
