Windshield Wiper Switch
redneckdude
Augusta, GA
Anyone ever had one go out? Mine doesn't work at all anymore, and started to smoke once...lol...pulled the fuse and all was well after that, but one day it just got hard to turn on and i gave it a little more force and heard some pop so im pretty sure the mechanism inside the column is shot...It isn't that hard to pull the steerin wheel off an change it, is it? Thats one of the few things i have yet to take apart on this truck. Also, what is the name of the actual part that the lever feeds into inside the column?
if no shorted wires anywhere then yeah most likely bad switch unit yep, techncally known as combo switch assembly, 84-up
good luck
to get into the column you will need a special tool, go to the parts store and tell them what your doing, if theyre good they will know
it hooks into the white turn signal switch in the column and has the dimmer switch rod hooked to it...
it CAN be replaced without special tools but the lockplate and retainer are a bear without a lockplate depressor tool (wow, deja vu). http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=10306&group_ID=1243&store=snapon-store&dir=catalog
you can get the wheel off the splines with either a puller or loosen the nut till its at the end of the threads and have someone shock it with a softface hammer while you pull on the wheel...
