Dafey
What size do i need? And who has them cheap? I need 2 right?
J/Y`s are out of the question here.
Where are you Dremu....
and if you have any 40A or bigger let me know.
I run 30A on mine and they have held up just fine, you can wire 2 in parallel for added confidence
Cant think of why I`d ever need to turn them off.Whichever way you go, I suggest you wire them so that you can turn them both off if necessary
LOL pretty hard to find mud/water here.So I plan to just get them hooked up for now, before the clutch fan go`s out. Then later on I`ll put a switch on the ground wire(s).I turn them off if I am going through a big mud hole, or if you are at a water crossing. Then you dont get mud or water sprayed all over
Not with me...Ill get bored and need something to do , then Ill do it.mmm yeah... we know how that goes... we will just do this for a bit.. which becomes permanent!!!![]()
